600E - Bad main bearings?
IL
Anyone had a problem with play in the main shaft bearings on the 600E? Mine is just a month old and I have to replace them. I can rock the shaft back and forth about a mm each way. Bearings are glued in the blocks.
I ordered the metal block kit and new bearings so hopefully that will solve it.[:'(]
IL
RE: 600E - Bad main bearings?
ORIGINAL: srouthouse
there should be no side to side play.
its way past time for new ones
ORIGINAL: []TEX[]
I love it...way past time you say? So these bearings only last 12 flights?[sm=50_50.gif] I would have figured Align to be better than that.
Folks around here have not reported a problem yet. OI have heard of one way bearing locking on early 600N.
Jim
IL
Thanks, but there isn't a way to miss align them since they have aligning tabs.
I pulled it apart last night and reinstalled with shaft in and it's still loose.
I have new parts in the mail.
I'll post here the result.
All I hear around here is that Align is the king of helis, yet I have had my Raptor for over a year and it's never had a loose bearing issue.
CA
the stock align bearings can be bad news and dont last long. its been noted even the replacement bearings seem to hold up better.
1mm is allot of movement.
when you move the shaft are you sure the outside race isnt moving. if the bearings are installed incorrectly its possible that the bearing holders are hogged out causeing the play because the whole bearing spun inside the plastic bearing holder. [something to check out]
pull the bearings out and check to see if there notchy and fit firmly in the plastic
FL
I have 3 600e's with well over 400 flights and no bearing problem. The way the bearings install it is pretty hard to mess them up. Very interesting!!!!!!!!!
