trex 450 tail wag
OH
Your gain is probably too high on your gyro (adjust it in the radio programming if possible)
Start at about 70% and go from their. Mine is at 68%
reduce the gain. other than that your belt could be loose causing it to skip, or your tail servo might have a broken gear or there is play in the linkages.
![](/forum/images/badges/premium_member.png)
Oldscale guy thanks for the help my belt is loose to Iam replacing it and all the servos rebuilding the heli I will let you know how things go when all done. Again thanks or the feed back and help you keep it all together Iam starting to get tiered of rebuilding this thing would love to be able to just fly around without having to put it back together every time I fly it owell will come with time. Steve
![](/forum/images/badges/trading_plus_member.png)
I had to do a lot of rebuilding on my Falcon 3D at first. It is getting better. This 450 is the first one i have really put together, even though it came in arf form. I have a friend here at work that is a very experienced heli flyer. He is going to take the 450 and fine tune it and get the radio equipment set up as it should be. He has been a big help to me. I don't think i would have ever got the Falcon flying right if it weren't for his help and would have probably given up by now. If you can find someone in your area to help you, it is very beneficial.
