3MM TOC 53 Numbers
TX
3MM TOC 53 Numbers
All,
3MM - 53 TOC
Alt - 830 feet above sealevel
Temp - 51 degrees F.
Gas- Shell Premium (92 Octane)
Oil - Penzoil Aircooled (Green)
Mix - 32:1
Prop - 3 bld CF thin (Mejzlik Copy ) GRS - 19x11 - 7300 static
- 2 bld Bunny Prop 23x8 (standard no the Graduated version) - 6900
- 3 bld Menz Ultra 22x10 wood - 6600 static
- 3 bld Mejzlik 22x10 CF - 6100 static
- 2 bld 3W wood 23x8 - 6520 Static
Stock Muffler (Large Exit stinger)
Reed Block mod and carb clocked with throttle and choke on top.
Strong motor will hover 17lb composite Extra 330L at 1/3 throttle on a 23x8 bunny prop.
Starts easy, Adjusts easy (not overy sensitive to needles)
Idles well inverted pulling over the top, does not die.
Sweetheart motor
jds
3MM - 53 TOC
Mix - 32:1
Sweetheart motor
jds
