Help, I need part from a broken .50 clutch
CO
Hi guys,
I lost one of the needle bearings in the one-way bearing that's inside the clutch. I had lubed it with Teflon grease, which was a bad idea cause it started to slip a bit when starting. So when I was cleaning it out a needle bearing went flying away. If someone has a broken 50V2 clutch with needles in there, could you pick one out and mail it to me? Thanks. -Tom
