Estes, Air Force One, 747
![](/forum/images/badges/premium_member.png)
I bought an Estes Air Force One 747, with 4 EDF's at a yard sale. It was designed to use differencial thrust as steering control, and full power to climb, no power to desend. It has 4 little ducted fans running brushed motors size 130s, each motor pulled 6 amps on 9.6 vdc which was what they had for power, but I don't think 8 little AAA nicads 650mah were going to put out a total of 24 amps, not for very long anyway.
It is all EPP foam and nicely painted.
I tore it apart as soon as I got it home (after I checked and marked the CG of the stock plane) I found a perfect place to put 2 servos for the tail surfaces, inside a compartment behind the wing, then rewired the motors to 2 brushed speed controls because I didn't have a single one large enough. Wired the inner motors to one esc, and the outer motors to the other.
Changed the electronics to a Spektrum system, and installed a 1800 3s 35c Hyperion lipo, above the wing, cut into the EPP foam.
It flew GREAT, sounds fantastic, 4 EDF's screaming is a very different sound.Seeing a 747 looping is cool.
I probably should have used 7.4 volts, because on the second flight, I burned out one motor, but I liked it so much, I am going to change it to 4 brushless motors and 4 ESC's, It will probably go balistic, may be be able to do some 3D because the inside motors blow right across the tail surfaces.
<br type="_moz" />
<br type="_moz" />
Wild-flyer .. FOR YOUR PRESENTATION ![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Cool...![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
VIDEO![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
[youtube]http://www.youtube.com/watch?v=wGMbhJbkBHc&feature=player_embedded[/youtube]
PIC![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Cool...
VIDEO
PIC
![](http://i346.photobucket.com/albums/p414/louloutex/IMGP3637-1.jpg)
