shift or not
RE: shift or not
it might be a wee bit lean just richin it up 1/16th or so of a turn (counterclockwise) and it should be ok,But if its rich you can tell by ALOT of blue smoke out of the exaust then lean it up a bit 1/16th or so (clockwise) then try it out..
PA
RE: shift or not
If you have had this truck for a while the "paw" in the tranny maybe sticking . See your book on this piece.Clean lube and re-assemble.
...Bob
...Bob
PA
RE: shift or not
Do you mean when it shifts from first to second while running fast?
If so, my first guess is you are a tad lean on the high end and it is flaming. Try richening the HSN 1/4 turn and see if it solves the problem. If HSN adjustments don't fix er up, then your going to need to investigate further, but first try richening the HSN.
