O.S 18 TM REVO EB FULLY MOD OR TRX 3.3??
NY
I got a revo 3.3 two weeks ago and the 3.3 leaves me wanting just a Lil more power. I was looking at the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLNG0&P=SM]O.S 18 TM REVO EB FULLY MOD From tower[/link]. what gears should I use with the o.s for better low and top end. As of now the hop ups I have are, rpm a-arms, rpm front and rear bumpers, tekno wing kit with proline wing, resonator tuned pipe, light weight aluminum turnbuckles and red aluminum push rods. Next up is the F.O.C kit. Also my revo sits in a crouch at full speed, what springs should i use to change that??
NY
RE: O.S 18 TM REVO EB FULLY MOD better than 3.3??
Im looking at doing more racing. I got a mgt that i bash with, btw i just order some 40 series proline velocity dish wheels and crimefighter tires.
RE: O.S 18 TM REVO EB FULLY MOD OR TRX 3.3??
DON'T get the EB mod os .18...they do hardly anything to there motors and there is no difference, i tried them, the mod looked stock and i didn't gain a thing. Get a non-modded one and send it here > www.abmods.com and you get a very fast turn around and a very good reliable guy, i get all my motors modded by him. He does great work and a full out mod it $85. this is just my opinion because the extra $100 isn't worth the $100
ORIGINAL: CrT-RaCeR
NY
Get [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHLV8&P=SM]this one[/link]?? What about the gears, what gears should I use?
YT, BOTSWANA
Depends who you ask i guess. I've seen a few of thoe EB mods TM's run. They are really fast. I've run the standard .18tm, and i have the stock 3.3 in my truck right now. The EB TM is way faster.
NY
what about my lil problem with the crouching on full throttle what springs would help me with that??
try the MIP clutch, and ThermalRD, yes its a little faster, but compare that to a AB Modded motor and it will smoke it soo bad it wont even be a race...
ORIGINAL: CrT-RaCeR
MI
ORIGINAL: CrT-RaCeR
Crankshaft is balanced
Crankshaft face is modified
Lightened and strengthened connecting rod
Lightened and modified piston
Cylinder sleeve is ported
Piston and sleeve is matched
NY
Mip clutch for the crouching??? How would that help with the suspension
ORIGINAL: CrT-RaCeR
ORIGINAL: ahfu25
ORIGINAL: CrT-RaCeR
ORIGINAL: happywing
It's WAY faster. Learn to tune.
ORIGINAL: CrT-RaCeR
NY
What i mean is the car squats in the back at full throttle and i wanted to know what springs would help eliminate that. Thanx for the input fellas
YT, BOTSWANA
Ahfu, for the suspension you can go to the progressive 3 rockers if you want. That'll help with squatting. And go with a heavier spring, and oil. I take it you are bone stock right now? Try the basic 3.3 revo racing setup on the Traxxas site. Its a bit firmer.
ORIGINAL: ahfu25
MI
To help reduce the "squat" in the rear end but still allow the Revo to have a soft feel while going over bumps, jumps, and cornering I had to change my rear springs the "TAN" Revo spring. You dont want to get to stiff or as CRT stated you can loose traction.
