picco .26 max airleek will idle with carb closed
ok now im well annoyed the engine was running lovely just a bit slow i had it a bit rich so i started tuning the engine then it was idling verry high so i reduced the idle untill there was no gap in the carb so i have another air leek and i cant even send the engine back now to find where it is lol
![](/forum/images/badges/trading_plus_member.png)
http://www.rcuniverse.com/forum/m_6388672/tm.htm
that didnt last long. what did you do to it. or rather what where you doing when you sprang a leak. they usually dont create airleaks unless you do something wrong.
yer verry true lol i sealed the front bearing up with some rtv and i guess the rtv ripped and wore out so now im stuck with a dud engine again is the bearing for the t-maxx 3.3 the same as i was told buy some one here
CA
^^^^yes i said that to you. the 3.3 engine beargin will fit the picco 26 max. get the boca bearing and dont RTV the old bearing up.
yeah i used my standard 2.5r bearing and i aint had no probz with my .26, pulls like 1000 horses(scale horses) lol
