gutting stock exhaust??
MD
RE: gutting stock exhaust??
there is a baffle in there sometimes it can melt and cause prablems, mine works fine i just want to take it out for noise/ power running cooler
WA
i have heard about drilling out the stinger to make it breath easier. i wouldnt mess with the inside. tuned exhausts are made specially so the backpresure can give the engine more power. if u mess with the inside of ur exhaust it can have the wrong timing and u will loose performance.
u want a more powerful pipe then just buy a new pipe, its an easy performance increaser and is relatively cheap. ive got a trinity for sale if your interested. 35 shipped. either go with a trinity or THS.
MD
i read in xrc car magazine that you can take the baffle out ot the pipe... so unless that mag is wrong then it can be done
WY
If you take out the baffle you have a resonator if you want pics for proof I will take them oh and the pressure valve on the resonator is a lil bigger also.
MD
i was just asking im not saying your wrong, i was just going by what i was told in the mag, i wanted to see if it was possable..
ORIGINAL: Clymer122693
Aaron
WA
^^^thank you for some comon sense....what he says is exactly true. if u want better performance and cant afford anything drill out the stinger. if you can afford to spend a few bucks by a tuned pipe for whatever motor ur runing. its not worth tearing into ur stock exhaust and messing things up.
WA
well its already pretty thin...try and use a drillbit that can barely fit in the stinger..then drill out...make sure its level so u dont warp the stinger or break through it. when ur done...wash it out so there is no metal shavings in the pipe....let it dry and bolt it back on.
