Advice for This Plane Please
I have this plane
I bought it from Hong Kong but I have some problems with radio and receiver
SPECIFICATIONS:
- FUSELAGE LENGHT: 37cm
- WINGSPAN: 50cm
- WEIGHT: 95g
I want to upgrade this plane I bought Hitec 4 Laser Rc and
555 Servo Sets with receiver.
When I buy two motors and a battery its weight will be 150 or 200gr I think
I found a program , its name MotoCalculator but I dont understand anything with it.
I want cheap motors for this plane and I need advice about motors from
[link=http://www.aircraft-world.com/shopdisplayproducts.asp?id=13&cat=motors+%2D+280%2 D300]This Online Shop[/link]
SPECIFICATIONS:
- WINGSPAN: 50cm
- WEIGHT: 95g
RE: Advice for This Plane Please
Run GWS IPS motors direct drive with 3x2 props, it'll haul butt.... Some LiPo's and small radio gear and you have a very cool plane. You'll end up in the 100-120g range, you'll probably want to put some carbon under the wing to keep it from flexing. You going to make it rudder/ elevator or aileron/ elevator?
Evan-RCU
Thank you for reply
I think you suggested me GW-EPS with Gear Box but I dont know Which one I should Purchase
If I buy anyone which propeller I have to buy
Plane's orginal propeller is 9,5cm
Thank you for reply
