VP RADIO PROGRAM SETUP FOR FUTABA 9C
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (646)
NC
Will someone please post the V P setup for a futaba 9 C .Please the procedure from A to Z for Futaba .....NOT JR.....I am trying to setup my Tx and need the exact way to do it.I want the VP to work on the throttle stick for total command with a switch to turn it on or off....Thanks in advance for your help....rcpilot007.....
GA
You have to set it up like a heli.....
with a pitch curve and throttle curve.
I used my watt meter to max out the watts/amps to figure out the best +/- pitch
You will need to experiment a bit...
with my set up, I would just flip the idle up switch to go into VPP mode
