Dead 36 motor or speed control?
GA
I finally received replacement transmitter after defective one came with original box. Fully charged battery, and all functions work fine.....except motor won't spin.
Cyclic works fine, as do all the other servos. Is there anything I can check with volt meter, or can I otherwise confirm the speed control is working?
The motor in the bird is the standard brushed 400 that comes stock.
Geez, and I had to wait 4 weeks for the replacement transmitter. YES, I've already placed an order for new radio to replace all of the Walkera electronics
thanks
thanks
With your voltmeter you can measure across the motor wires to see if there is any voltage going into it as you throttle up (make sure the motor pinion in NOT engaged with the main gear though just in case it does suddenly fire up!). if there is good voltage then it is the motor - no voltage its the speed controller.
Also make sure you have the transmitter switched on first and the throttle and the throttle trim all the way down when you plug in the battery as anything above idle will stop the ESC from arming.
Sounds like yours may have been put together on a Friday
Mine was built on a Wednesday (everything works) but was shipped on a friday (got bashed around and bent everything!)
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
GA
Seacomms
Thanks, you're brilliant. It worked! Seems this forum is quickly becoming the Users Manual for the bird.
Thanks again
Thanks again
