Walkera 22E and Feigao Brushless Tail Motor
TX
What ESC would i need to run this motor Brushless Tail motor ( T5 Heil version ) short or long at [link=http://helihobby.com/html/motors.html]Helidirect[/link] the motor is about half way down on the page.
I keep burning out tail motors and i have enough electronics to go separates minus the tail motor and esc. I just need to know what tail motor esc i need to run in order not to burn it out as well. Im running Li-po's 1200mah 11.1 10c batteries BTW. I have a brushless setup for the main motor all ready with ESC.
Here are the specs i found on the Feigao 1208430S 12x22mm Brushless Motor (short)
Kv: 5250 RPM/V
No Load Current: 0.2A
Resistance: 1 ohm
Max Voltage: 7.4V
Max Current: 2.0A
Max Watts: 15W
Weight: 10.5 g / 0.37 oz
Size: 12mm x 22mm
Shaft Diameter: 1.5mm
Poles: 2
Kv: 5250 RPM/V
Resistance: 1 ohm
Max Voltage: 7.4V
Max Current: 2.0A
Max Watts: 15W
Size: 12mm x 22mm
Poles: 2
I'm done. I can't seem to learn how to fly this thing.
I have three of them on sale at eBay, NO RESERVE on any of them.
Non working one, only good for parts : http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EF:US:11
Working condition: http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EF:US:11
Modified + Upgraded w/ CNC Head + Brushless Motor + Speed Controller cost me over $350: http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:EF:US:11
Good Luck.
Good Luck.
