best battery and motor for the walkera 60 and any other upgrades
I just got my new toy and I was quite pissed about the battery and the chargerthat come with it, instructions suck as well No detailed instructions on what to do with the battery so I pluged it into the chopper and worked it till the rotors wouldnt spin any more then I charged it it didnt take about 20 min and the battery was hot *** am I doing wrong?
also after this I can get the skids off the deck about a inch and thats it no higher did I already fry this battery?
It will spin the rotor at full throttle I can dance the plane around the ground but it barely gets off the deck so is it the battery or do I need to adjust the shashplate? I see plenty of movement but what should I have on the blade pitch ? give it to me in inches please hahah
If I do need a battery I want to get something better so I need some advice on what to get because im a newby
I also wouldnt mind putting in a motor with some balls so if that coincides with a new battery id like to do them at the same time.
I already have the CNC head and tail rotor but I want to save them for after my big crash that I know is comming sometime.
but for now I want the power to get it off the ground.
what other upgrades are out there? this is my training aircraft and I will be going bigger in the future but I want to wear this thing out and do it right.
thanks
johnny
thanks
johnny
FL
RE: best battery and motor for the walkera 60 and any other upgrades
Most people upgrade to this Elf Hobby 4200kv motor and 30a ESC.
http://www.ehirobo.com/shop/product_...oducts_id=4046
This 15c 2200mAh Li-Po battery works well with the above motor.
http://www.ehirobo.com/shop/product_...oducts_id=4433
