Do you guys think this is a good balance charge
Would this be a good charger for a 7.4v 8c 1300mah lipo? [link]http://ALIGN Lithium Battery Balance Charger LIPO 2-4 CELL (#2500875591350) ON EBAY
IL
BUBBA633,
Can't see that item...it doesn't appear to be a valid number. Keep in mind that you can also buy a non-balancing LiPo charger initially, then add a balancing adapter later. This is what I did - now I'm looking at getting a 'Blinky' balancer to go with my charger. With it I'll be able to balance charge packs up to a charge rate of 2.5A, which is the limit of my charger.
Sorry, I dont know how to link the item from ebay here. Below is the spec's of the battery. I don' know anything about these things, Is this a good one?
BRAND NEW IN FACTORY PACKAGE WITH FULL MANUFACTURE WARRANTY
Align New 2-4 CELL Lithium Battery Balance Charger RCC-4CX
FEATURES:
1.Reverse polarity protection and short circuit protection.(warning beep)?
2.AC 100-240V exchange switch for international specification.
3.Supply 3.6V / 3.7V 2-4 cells Li-ion/Li-polymer battery.
4..For both balance charge and charging in series. It is a fast, convenient design.
5.Balance charging is good to prevent the situation of over-charging or under-charging for a single cell.
6.Auto-detected charge status display. (Red light: while charging Green light: end of charging)
7.Cooling fan and multi-circuit protection to avoid the dangerous of charging.
8.The auto-detected function of low voltage for power storage.
Charge Method:
1.Series DC7.4V JST connector X 2 sets (no more parallel charge plug in)
2.Series DC11.1V 20A connector X 1 set(no more parallel charge plug in)
3.Balance DC7.4V connector X 2 sets
4.Balance DC11.1V connector X 1set
5.Balance DC14.8V connector X 1 set(avalible refit to DC11.1V balance connector )
Single cell circus can be parallel charging 2 sets at the same time by balance charging. Divide up 500mAh for 2Cell. The maximum suggestion is 8cell for parallel charging.
Specification:
?Dimension: Length 135 x width 80x height 35 (mm)
?Series no: RCC-4CX
?Input Voltage: AC 100-240V 50-60Hz
?Output Voltage: 2cell DC 7.4V
3cell DC 11.1V
4cell DC 14.8V
?Output Current: 1000 mA/cell
Precaution:
Note!
If the battery becomes hot while high current discharging or flying, please do not charge the battery immediately. Wait to cool down(about 20 mins), then inspect to recharge. If against follow the original factory using rules, possibly cause the battery to inflate or any dangerous accident happens.
?Recommend this Li-ion/Li-polymer charger for the safty and efficiency of battery.
# KX850140A
FEATURES:
Charge Method:
Specification:
?Series no: RCC-4CX
3cell DC 11.1V
4cell DC 14.8V
Precaution:
Note!
# KX850140A
IL
BUBBA633,
If you want to go cheap, why don't you get this charger:
http://www.helidirect.com/product_in...roducts_id=745
Just keep in mind that these cheap chargers only put out .8A to 1A, so if you go to charge a 2000mah pack it's going to take a couple of hours. That's the difference between the cheap chargers and more expensive ones...the expensive chargers usually go up to around 3A output.
