52 and 52-1 lipo ?
AZ
Thunderpower 370mAh are just slightly bigger and more bang for your buck, but just about anything other than stock pack will help. Try Hextronic from United hobbies or maybe Polyquest batteries (400mAh/11.1V) for a bargain set (about $23.50 @ hobbylobby). The 800mAh is about $32 and only weighs an ounce more. I'm sure it'll work, but I'd stick with the 400's or less for stock/brushed setups.
You can put a slot-car motor in it and get a bit more headspeed out of it making the extra heft easy to handle.
AZ
Sorry for the slow response.
Hotslots carries them for $23.99. P/N 3015-815. It's called an NSR King 38,500 (you can just google NSR King 3850 and it should come up). You have to put it in backwards wired I think (make sure you test it before final install).
WV
Thanks for the info. skunk. I was just looking at the lipo that comes with the new 64-c and it is 480mah and is cheaper than the lipo for the 52. It is only 19$on fleabay.
