Is there any reason...
...Why these parts wouldn't work with my belt cp v2?
www.xheli.com/exicncmerohe.html
EXI 450 metal head and tail rotor. It's on for $39.99 which sounds like a good deal to me.
RE: Is there any reason...
It will work if you make it. The main shaft that comes with this combo is meant for trex 450 se v2 so you have to end up using the stock main shaft that come with belt cp v2. Also the ball link will be smaller on the belt cp v2 so you have to change those as well. For the tail you might end up using the stock belt instead of the belt that comes with the tail.
Andy
Andy
MD
Antirotation pin in the swash is also in the wrong place for a belt cp. That will have to be dealt with.
Your belt CP shaft MAY need to be shortned 2mm. That's what I had to do when putting one on a HBK2.
Thanks dditch
wobbles99, if you can't do all this you can get this one: http://www.xheli.com/esbecpalheup.html
Andy
Andy
