Battery connects to ignition...HOW?? RCS 140
My Feedback: (508)
I have a new RCS 140 and am not sure how to connect the battery...
On the ignition module, there is the square, black, male connector.
Which of these male plugs is negative and which is positive??? If I'm looking at the module from the end... is the one on the right positive???
Larry
Larry
RCS 140
Why don't you contact the distributer - RCS - they should be able to give you all the info you need. They have their own WEB, and can be contacted via RCUNIVERSE. Good luck......... you will enjoy that engine if you break it in as per instructions.
My Feedback: (508)
Thanks...
The instructions that came with the engine don't say anything about the polarity ... but I went to RCS's webpage... and the instruction manual they have online (different from mine) says which is positive and negative...
Seems like they would have put these instructions in the engine box...???
Thanks and the left one is positive...!
Larry
Larry
